    Solved NES new configuration for controllers not working
    GamePad/GPIO/USB encoder
    nes
    2302
    • RodsBrito
      RodsBrito last edited by
      Hi there,
      I've just follow this page https://github.com/recalbox/recalbox-os/wiki/How-to-use-custom-config-for-emulators-(EN), since I want to remap the NES buttons.
      but...
      After saving the recalbox.conf, when a started any nes game, the system says:
      "failed saving config to (my dir)", and nothing works... I have to shutdown the system...
      What am I doing wrong? this is what I've added - nes.configfile=/RECALBOX/share/system/.config/retroarch/config/remaps/FCEUmm/NEScontrollers.cfg
      thanks
        paradadf Staff @RodsBrito last edited by
        @rodsbrito try writing /recalbox/... wirh lower case.
        RodsBrito 1 Reply Last reply Reply Quote 0
        • RodsBrito
          RodsBrito @paradadf last edited by
          @paradadf I’ve tried, but when I click on the “save” button, the word recalbox saves with upper case...
          Weird...
          Any more tips?
            OyyoDams Staff @RodsBrito last edited by
            @rodsbrito what editor do you use ?
            • RodsBrito
              RodsBrito @OyyoDams last edited by
              @oyyodams said in NES new configuration for controllers not working:
              Hi, I'm using a PC web browser
                @rodsbrito please use a true file editor
                • RodsBrito
                  Hi, now it finally works
                  tried two things:
                  a) used notepad++ to edit the config file
                  b) change from nes.configfile=/RECALBOX/share/system/.config/retroarch/config/remaps/FCEUmm/NEScontrollers.cfg to nes.configfile=/recalbox/share/system/.config/retroarch/config/remaps/FCEUmm/NES.cfg
                  not sure exactly what was the problem...
                  thanks for all your time and help
