    Organize roms Mame
    organize roms mame
    • ricardoclaus
      ricardoclaus last edited by
      Guys, in Recalbox 6, how do I organize all roms for MAME? Recalbox 6 is compatible with several versions of MAME 2003, 2010 iMameAll and etc ... Should I put all romsets in a specific folder?
      • olivierdroid92
        @ricardoclaus
        You might be read these topics
        https://github.com/recalbox/recalbox-os/wiki/Easy-Arcade-on-Recalbox-(EN)
        https://github.com/recalbox/recalbox-os/wiki/Advanced-Arcade-on-Recalbox-(EN)
        I think all is indicated 🙂
        Have fin
        Personnaly I've choosen 2003-Plus romset
        ricardoclaus 1 Reply Last reply Reply Quote 0
          Zing Global moderator Translator @ricardoclaus last edited by
          @ricardoclaus Recalbox recognizes more than one Mame romset, but you do not need to use more than one romset. All Roms of Mame should be placed in the Mame folder, regardless of the romset, you will only need to change the emulation core per game if you have several romset mixed.
          • ricardoclaus
            ricardoclaus @olivierdroid92 last edited by
            @olivierdroid92 Thanks for the tip, I'll read the material you indicated.
            • ricardoclaus
              ricardoclaus @Zing last edited by
              @zing Thank you for your help. I will proceed as you instructed.
