    How many 8Bitdo SN/SF Pro pads can be paired simultaneously?
    GamePad/GPIO/USB encoder
    many 8bitdo snsf pads paired
    • MarcDK
      MarcDK last edited by
      Hi,
      can pair 5 or more pads at the same time with a Raspberry 3b+ and Recalbox 6.0? Or do I need to use an XBOX 360 USB adapter? Or do I need two XBOX 360 USB adapters for more than 4 pads?
      Cheers
      • Marc
      https://marc.tv
        voljega Banned @MarcDK last edited by voljega
        @marcdk recalbox doesn't support more than 5 pads.
        Xbox360 dongle doesnt' support more than 4 pads
        Nit sure than 2 adapters will wotk, Windows 7 only supports up to 4 xbox360 pad for instance, if you connect a fifth it is not detected (but 4;xbox360 + 1 ps4 is ok)
        • MarcDK
          Ok. Thanks. And what about Bluetooth or mir specific 8bitdo pads? Can Bt handle 4 or more pads?
          https://marc.tv
            paradadf Staff @MarcDK last edited by
            @marcdk yes, it can.
