    [Solved] Custom game configuration
    [solved] custom
    • niehztog
      niehztog last edited by
      Is it possible to have different controller button configuration for each game? For example, there are some GBA games which do nopt work well with the default button layout. Would it be possible to adapt the buttons only for specifiy games?
      • digitaLumberjack
        Hi, not it's not possible.
        • niehztog
          Hi digitalLumberjack, thank you for your reply. Would it be possible then to change the button configuration only for one emulator? For Example to switch A and B buttons only for GBA emulator?
            @Nils , yes look this page only with libretro core : https://github.com/recalbox/recalbox-os/wiki/Custom-controller-mapping-for-specific-system-(EN)
            • niehztog
              Thank you, exactly what I was looking for. 🙂
