    Rpi0/1 fbalpha optimizations
    Testers's corner
    rpi01 fbalpha optimizations
    3199
      paradadf Staff last edited by paradadf
      ONLY FOR RPI0/1 VERSIONS OF RECALBOX
      As I don’t own a rpi0/1 myself, I need you, dear community, to test this compiled version of the fba_libretro emulator fbalpha on your boards. It should be on par with pifba (fba system emulator) regarding performance, so users of the lower end boards can use a newer romset and all libretro ports benefits.
      Here is the binary for testing performance differences between fba and fba_libretro:
      http://s000.tinyupload.com/index.php?file_id=01516935153730933111
      (Re-)place the file inside usr/lib/libretro
      And set the appropriate permissions on the file:
      chmod u+x fbalpha_libretro.so
      Don't forget to make the partition rw before trying to copy it over:
      mount -o remount,rw /
      To be able to test the optimization, you’ll need to activate the Cyclone option in retroarch’s menu.
      It might also be useful to set frameskip to 1.
      Don’t forget fba uses the 0.2.96.71 romset and fba_libretro the 0.2.97.44 romset.
      Please compare the same game, from their respective romset version of course, and report if performance is similar between both.
      Thanks everyone!
      1 Reply Last reply Reply Quote 4
      • cissou
        cissou last edited by cissou
        oky so I tested it on a pi0
        and so far
        fba_libretro a little slow
        street fighter 3 zero euro : 37 fps
        metal slug 1 : 37 fps
        art of fighting 3 : 37 fps
        I haven't tested with fba_libretro stock for the fps
        i don't know how to show fps on pifba (maybe can't possible)
        under pifba
        street fighter 3 zero euro: very speed
        metal slug 1: perfect
        art of fighting 3 : perfect
        Dell 3020M + X360 sans fil
        Bartop Modulaire : Rpi3
        paradadf barbudreadmon 2 Replies Last reply Reply Quote 0
          paradadf Staff @cissou last edited by
          @cissou I never tried to show the fps in pifba, but I suppose it is either not configured on recalbox or not implemented in the emulator.
          @barbudreadmon any experience on retropie with this optimization?
          • barbudreadmon
            barbudreadmon @cissou last edited by
            @cissou Did you enable the related core options ? "Cyclone" must be enabled, it might also be a good idea to test with a "frameskip" value of 1.
            Libretro developper :
            • FBAlpha FBNeo (Arcade)
            • Kronos (Sega Saturn/ST-V)
            • YabaSanshiro (Sega Saturn)
              paradadf Staff @barbudreadmon last edited by
              @barbudreadmon I wasn’t aware of the need to activate the option on retroarch. I’ll add it to the description. Thanks!
              • cissou
                oky i will test with the cyclone activated
                • cissou
                  So I activated the cyclone option and I gain 3/4 fps (so about 42/43 fps) with frameskip at 1
                  • barbudreadmon
                    @cissou Those numbers are surprising, it would mean there is no performance gain at all from using the dynarec. You left the game and re-launched it after enabling the option, right ?
                    • cissou
                      yes, and those parameters are saved so i don't need to activate every time
