    Kodi
    kodi
    • N1tr0XL
      N1tr0XL last edited by
      Hello
      Kodi does not launch when the controllers are connected (USB or bluetooth)
      when there is only the keyboard Kodi works.
      Raspberry 3b+
      Recalbox 6.0
      • N1tr0XL
        Hello,
        please help me, kodi doesn't work :
        Fichier en cours de visualisation : /recalbox/share/system/.emulationstation/es_log.txt
        [2019/05/20 07:29:16.817] (INFO ) : Attempting to launch kodi...
        [2019/05/20 07:29:16.817] (INFO ) : Shutting down SDL AUDIO
        [2019/05/20 07:29:17.246] (INFO ) : Available and configurated : ShanWan PC/PS3/Android
        [2019/05/20 07:29:17.246] (INFO ) : Saved ShanWan PC/PS3/Android for player 0
        [2019/05/20 07:29:17.246] (INFO ) : Saved ShanWan PC/PS3/Android for player 1
        [2019/05/20 07:29:17.246] (INFO ) : No config for player 2
        [2019/05/20 07:29:17.246] (INFO ) : No config for player 3
        [2019/05/20 07:29:17.246] (INFO ) : No config for player 4
        [2019/05/20 07:29:17.246] (INFO ) : Configure emulators command : -p1index 0 -p1guid 03000000632500007505000010010000 -p1name "ShanWan PC/PS3/Android" -p1nbaxes 4 -p1devicepath /dev/input/event0 -p2index 1 -p2guid 03000000632500007505000010010000 -p2name "ShanWan PC/PS3/Android" -p2nbaxes 4 -p2devicepath /dev/input/event1
        [2019/05/20 07:29:17.833] (INFO ) : Creating surface...
        [2019/05/20 07:29:17.861] (INFO ) : Created window successfully.
        [2019/05/20 07:29:18.537] (INFO ) : Added known joystick ShanWan PC/PS3/Android (instance ID: 0, device index: 0)
        [2019/05/20 07:29:18.607] (INFO ) : Added known joystick ShanWan PC/PS3/Android (instance ID: 1, device index: 1)
        [2019/05/20 07:29:19.057] (INFO ) : SDL AUDIO Initialized
        [2019/05/20 07:29:19.057] (INFO ) : playing
        [2019/05/20 07:29:19.057] (WARN!) : Shutdown terminated with non-zero result!
          OyyoDams Staff @N1tr0XL last edited by
          @n1tr0xl please don't double post. https://forum.recalbox.com/topic/17149/kodi-ne-fonctionne-pas/8
