    What about av out? (Raspberry Pi 3)
    hdmi avcomposite
    1825
    • Virtuadream
      Virtuadream last edited by
      I made the jump from retropie to recalbox for the "demo" feature.
      How do I make to get picture from the av out? Or recalbox is HDMI only??
        Zing Global moderator Translator @Virtuadream last edited by
        @virtuadream Read the Wiki:
        https://github.com/recalbox/recalbox-os/wiki/Connect-your-recalbox-to-a-CRT-with-composite-(EN)
        https://github.com/recalbox/recalbox-os/wiki/Mini-How-To-(EN)#audio--video
        • Virtuadream
          Ok, in the wiki says " Make rw partition: [mount -o remount,rw /boot]" I entered that comand but it does nothing, Im still unable to edit the config file...
            @virtuadream Make sure you typed exactly the same as the tutorial says, I connect via HDMI and have never done that, but I know it works. If you search YouTube you'll probably find some other tutorial as well.
            • Virtuadream
              Tried typing with a keyboard, it hasnt change anything.
              Been fiddling with the options on a 4:3 monitor trough HDMI, "auto aspect" doesnt work properly. 16:9 looks like 4:3.
              I miss retropie but I love this demo feature 😕
                @virtuadream https://youtu.be/ng_41iswBWo
                • Virtuadream
                  Welp, inserted sd directly I was able to save the config did it on Windows 10.
                  Thank you.
