    Amiberry and recalbox 6
    Emulator Arcade/PC/Console
    amiberry recalbox
    • Asirome
      Asirome last edited by Asirome
      Hi,
      Thanks for your work in recalbox! it's a nice project.
      I have some questions for the amiberry emulator in recalbox:
      • How I can save a custom setting for a game or general change in the emulator? I have changed some configuration in the UAE config screen, clicked on all 'save' buttons that I have found, but the settings seems not permanetly.
      • Another question is the .7z support, with .zip and whdload games, works fine, but with .7z and whdload a write protected disk message appears in the amiberry, and the game is not running.
      system: Raspberry 3B+
      maybe I'm doing something wrong?
      thanks!
      chris72 1 Reply Last reply Reply Quote 0
        Hello
        • 7zip not supported
        • zip or lha only
          https://gitlab.com/recalbox/recalbox/blob/master/package/recalbox-romfs/recalbox-romfs-amiga1200/roms/amiga1200/_readme.txt
        • chris72
          chris72 @Asirome last edited by chris72
          @asirome In the directory /recalbox/share/roms/amiga1200 create a file named .uaeconfig.uae
          IMPORTANT is the POINT in front of it, otherwise the file will not be loaded!!!
          In this file I have only two lines in it, which will be overwritten by the default configuration:
          show_leds=false
          amiberry.use_analogue_remap=false
          Of course you can overwrite as much of the default configuration as you want!
          • Asirome
            @chris72 many thanks! I read in the documentation something like that, but I don't know the exact location and the name of the filename to do it.
            @acris maybe in the next release will be support for 7z?
            thanks!
              @Asirome
              No, this extension is very poorly supported,not functional by amiberry
