    Problem with Recalbox 6.0 x86
    recalbox 6.0 x86
    2626
    • Jarkan
      Jarkan last edited by Jarkan
      Hello and congrats for a job well done!
      I have experiencing a problem using the 6.0 x86 version of recalbox on my laptop or my main PC and the PC at my job.
      It boots until Emulationstation but just in the main menu it jumps back to the Recalbox loading screen with the blinking cursor.
      I still can access via network to the filesystem but nothing else.
      With the frebruary beta version, just works as it should.
      Regards!
        Zing Global moderator Translator @Jarkan last edited by
        @jarkan Are you sure there was no problem at the time you burned the image? Or that you are not with the corrupted image file? Download the image of the last official version again, do a clean install, and wait for the first boot to the end.
        Jarkan 1 Reply Last reply Reply Quote 0
        • cyborg276438
          cyborg276438 last edited by
          hi . i have same problem with x86 .
          x64 work ok .
          i testet x86 with two desktop pc and 1 laptop . emulationstation comes up for 3sec and exit to console .
          give some i/o error 4 and xserver connection disconected.
          • naxma
            naxma last edited by naxma
            Hi,
            I have the same problem too. Tested on three PCs, one with a 32-bit atom processor, one with core 2 duo and the last with I7 8700K.
            Recalbox starts up, goes to the main graphical screen, the music starts and a moment later it exit to the terminal.
            In verbose mode, this is what is reported (see image)
            https://drive.google.com/file/d/1PSDt8yO-E0nyxapCkM8vieP8KAz_eo9b/view?usp=sharing
            x64 version work ok.
            • cyborg276438
              why dev and support team dont awnser?
              • Jarkan
                Jarkan @Zing last edited by
                @zing I am sure. In fact, the problem is the same for more people.
                  @jarkan I understand, if they seem to be a common issue, I recommend you explain in detail, on the official topic:
                  https://forum.recalbox.com/topic/17162/recalbox-6-0-is-out-codename-dragonblaze
                  Do not forget to reference this post.
