    [Recalbox 6.1+][Snap Videos] Thème ALEKFULL NX
    Themes & Interface
    theme alekfull recalbox dragonblaze snap videos
    13
    21
    28404
    • fagnerpc
      fagnerpc Theme moderator last edited by mYSt
      Hi guys 🙂
      ALEKFULL NX was inspired by the direct and intuitive interface of the current Big N console, the Nintendo Switch.
      Arts in 4 resolutions (FULL HD, 900p, HD and 540p)
      Are there many systems and the theme is getting too heavy?
      Use the LITE resolution (540p) for greater fluidity. Access the Main Menu, then go to Interface Options, Theme Configuration, and System View Theme.
      Recommended also to run the Recalbox in 720p (which greatly improves the quality of the arts and performance of Raspberry Pi).
      SEGA CUSTOM COLLECTION
      Two color options: Light and Dark
      Each selected color option reflects too in the menu, list of games and even pop-ups 🙂
      alt text
      alt text
      Iconsets in 9 options (2 Exclusives)
      In this theme, we made 2 unique iconsets (PS and Switch) - totaling 9 available icons options 🙂
      alt text
      alt text
      • RECALBOX compatible with the update 18.03.16 onwards;
      • Credits for the layout of the logos go to Lilbud: some logos were made by him -the rest are custom ones made by me;
      • Compatible with more than 150 systems: all Recalbox systems - including recent ones like Naomi and Amiga CDTV and custom systems.
      Version 6.0 Dragon Blaze Available here
      UPDATE 6.1 DRAGONBLAZE
      • Added Apple II GS, Amstrad GX4000, Macintosh, OpenBor, Palm, Spectravideo, Uzebox, Sharp X1, Solarus, MSX Turbo R, NEC PC88, N64DD and Multivision systems;
      • Updated arts (30% of the arts was updated);
      • Two new color options available: Blue and Black;
      • Code and images optimized for less use of Raspberry Pi Vram;
      • I changed standard color for Dark and arts resolution to 540p (options for 1080p, 720p and 900p remain available)
      • Support for video snaps 😉
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      Version 6.1 Available here
      ARCADE ALEKFULL
      • mYSt
        mYSt Theme moderator last edited by
        Nice work, nice carousel!
          Great job, i'll test it soon 🙂
          • Memories Dark
            Memories Dark last edited by Memories Dark
            Peut on associer les musiques a une plateforme de jeu ou sont elle obligatoirement en aléatoire ?
            Merci a vous .
            • Fab2Ris
              Fab2Ris Staff last edited by
              Could be great to think about EDIT EACH FIRST THEME POST to indicate before anything... witch version of Recalbox is compatible with this theme.
              Like : TESTED/Works on Recalbox 6.0 RC2 (DATE OF TEST)
              And edit the post title, for exemple : THEME : Next Pixel (OK Recalbox 6.0, April 15), or THEME : Next Pixel (Recalbox 18.xx.xx OK, Recalbox 6.0 WIP)
              This information must be on the name of the theme + topic, to see if there is update avaiable for theme's users.
              And on the other hand, it's very important, to see if there is all systems supported, and not particular problem...
              What do you think about ?
              Tuto Maker et Community Manager de Recalbox (Facebook/Twitter/Instagram/YouTube...)
              fagnerpc 1 Reply Last reply Reply Quote 0
              • fagnerpc
                fagnerpc Theme moderator @Fab2Ris last edited by fagnerpc
                @fab2ris said in (THEME) ALEKFULL NX /// for Recalbox 18.03.16 +:
                Well, it's a good idea ... I've already indicated the compatible versions since my first theme, but I'll try to be more specific in the topic title.
                As for systems, I also indicate supported systems ... in this NX theme for example, April 1st systems are available too - PS2, PS3, WiiU (haha)... and 150 + systems
                The main problem: I can not edit any of my first posts on any of my topics. Only moderators edit them.
                I am constantly updating my themes and I can not update the download links or the first post.
                Take my first Alekfull theme for example ... I updated it already has more than 6 months, I posted in the topic, but the version that has in the first post is totally outdated
                ARCADE ALEKFULL
                  @fagnerpc
                  your theme is compatible with recalbox 6 DragonBlaze ?
                  • fagnerpc
                    fagnerpc Theme moderator @acris last edited by
                    @acris said in (THEME) ALEKFULL NX /// for Recalbox 18.03.16 +:
                    @fagnerpc
                    Yep, is compatible with Recalbox 6 DragonBlaze 🙂
                    ARCADE ALEKFULL
                      hello @fagnerpc
                      I tried your theme 540p, on Samsung TV 4K on rpi3b+ with only SDCard , because in 1080p somes pictures disappers.
                      Your theme is very beautiful,
                      I really like the chosen artkworks
                      Bravo !
                      • Alexander
                        Alexander last edited by Alexander
                        Hi @fagnerpc
                        First of all, your theme rocks, and NX will be my main theme from now on!
                        I'm customizing it a bit, and I'm trying to change the images for some systems.
                        I'm just putting my images in the 720p folder (the setting I use) using the name of the system I want to change and erasing yours. It works well in the carrousel, but when I am inside the system browsing the games, the background image is still the old image (yours).
                        Do I have to susbtitute the image somewhere else or edit any config file to make it fully works?
                        Thanks in advance
                        EDIT: I found it! The system background image is being read from the 540p folder.
                        For anyone who wants to add custom images, it's just better to create the 1080,900,720 and 540 versions of the image and overwrite them.
                          Hello @fagnerpc
                          To anticipate an updated theme for recalbox 6.1
                          Some info New Core :
                          New system! Uzebox on all systems (RetroArch core: libretro-uzem)
                          New system! Amstrad GX4000 added with libretro's cap32 emulator
                          New system! Apple IIGS on all systems (Standalone: GSplus 0.14)
                          Pi 3A+ compatibility (Firmware b*mp)
                          New system! Spectravideo added with libretro's bluemsx emulator
                          New system! Sharp X1 added with libretro's xmil emulator
                          New system! Palm added with libretro's mu emulator
                          • fagnerpc
                            fagnerpc Theme moderator @acris last edited by fagnerpc
                            Hello @fagnerpc
                            Hello @acris... thx for the feedback
                            I updated the theme with the systems you mentioned, plus some systems for future updates
                            • Added Apple II GS, Amstrad GX4000, Macintosh, OpenBor, Palm, Spectravideo, Uzebox and Sharp X1 systems;
                            alt text
                            alt text
                            Available here
                            ARCADE ALEKFULL
                            • jpdonald
                              jpdonald last edited by
                              Très beau theme.
                              Baisser la résolution des images évite quelques pages blanches;
                              Petite info, on peut baisser la résolution en gardant l'échelle mais aussi en compressant l'image sur sa longueur et garder la résolution verticale. (un peu comme les dvd vidéo en 16/9 où l'image est étirée).
                              Notre oeil est beaucoup plus sensible à la résolution verticale.
                              MERCI
                                Hello @fagnerpc
                                Is it possible to have your optimized theme for gpi case 240p?
                                • brice68
                                  brice68 last edited by
                                  J'adore ce thème par contre écran noir au retour des jeux sous 6.1 alors que je n'ai pas ce soucis avec le thème recalbox. Une compatibilité en vue ?
                                  • fagnerpc
                                    Hi guys,
                                    I updated the theme with the new systems of the 6.1 update and added video snaps 🙂
                                    • Added Solarus, MSX Turbo R, NEC PC88, N64DD, Multivision systems;
                                    • Compatible with more than 150 systems: all Recalbox systems - including recent ones and custom systems.
                                    alt text
                                    alt text
                                    alt text
                                    alt text
                                    alt text
                                    alt text
                                    alt text
                                    Available here
                                    ARCADE ALEKFULL
                                    • chenteparao2
                                      chenteparao2 last edited by
                                      Awesome job, can someone include games collections lis 2 players, 4 players and all games in this theme?
                                        @fagnerpc
                                        thanks for update, my favorite theme 😄
                                        • Mijer
                                          Mijer last edited by Mijer
                                          Hello everyone,
                                          Thank you for you work @fagnerpc ! As a designer I have to say this is a clean job 🙂
                                          I am pretty new to the Recalbox world (my dad & mom builded me a ready-to-play bartop), so i'm actualy quite lost with all of this.
                                          The V.6 is working great, but the V.6.1 doesn't. When I select it from the menu, the loading screen never end... What I did :
                                          • Downloading your theme
                                          • Uncompressing it
                                          • Uploading the theme folder to my recalbox theme folder (with FTP SSH)
                                          • Selecting the theme on my recalbox menu
                                          • Waiting for the installation... but it never end (i waited more than 5min)
                                          What can I do ? Maybe I have the wrong update of Recalbox... ?
                                          If you need some help for designing new theme, this would be a pleasure to help !
                                          See ya, and thanks again !
                                          • sergioad
                                            sergioad last edited by
                                            I love it, thank you very much
