    Solved Problème thème officiel Recalbox encore une fois
    thème officiel recalbox fois
    • WisePixel
      WisePixel last edited by
      Désolé d’intervenir une fois de plus sur le thème Recalbox-next et merci beaucoup d'avoir corriger les proportions de la Megadrive.
      J’ai oublié de mentionner une autre erreur de proportion. Cela concerne le logo 16-BIT sur la Megadrive japonaise. Le vrai logo est plus grand et ce n’est pas la même police de caractère. Sur le thème actuel il est identique à la version européenne. Encore désolé, je ne fais que remonter l’information.
      Bon jeu à toutes et à tous !
      Hello,
      Sorry to speak again on the Recalbox-next theme and thank you very much for correcting the Megadrive proportions.
      I forgot to mention another proportion error. This concerns the 16-BIT logo on the Japanese Megadrive. The real logo is bigger and it's not the same font. On the current theme it's identical to the European version. Still sorry, I'm just tracing the information.
      Good game for all ! (sorry for my English)
      Insert coin
      OyyoDams paradadf 3 Replies Last reply Reply Quote 0
        OyyoDams Staff @WisePixel last edited by
        @wisepixel @paradadf ?
          paradadf Staff @WisePixel last edited by
          @wisepixel finding the exact same font is an usually difficult task, so I try to approximate it the best I can, without spending hours looking. But about the size of the letters "16-BIT"... you are completely right and it should be bigger. Would you help me finding the right font, please? And if it isn't too much to ask, I'd rather prefer to discuss such things directly by opening an issue https://gitlab.com/recalbox/recalbox-themes/issues, so I don't forget about it. Please, open an issue about this there... that way you'll directly get notified when your stuff gets fixed. Thank you!
            paradadf Staff @WisePixel last edited by paradadf
            @wisepixel no need to open an issue. I just found a similar font and corrected it. I don't know if it will make it into 6.0, but 6.1 for sure.
            WisePixel 1 Reply Last reply Reply Quote 1
            • WisePixel
              WisePixel @paradadf last edited by
              @paradadf Thank you very much, you're amazing ! If you need my help, I'll do my best !
              Insert coin
