    Recalbox 6.0 RC3 and Intel Wireless AC7260
    GamePad/GPIO/USB encoder
    recalbox 6.0 rc3 intel wireless
    • daarky
      daarky last edited by daarky
      Hi everyone.
      I am using Recalbox RC3 (x64) on a Sandisk 64gb USB stick and I'm having problems using my Intel Wireless AC7260 with my Acer Aspire V5-573g. After a fresh installation of Recalbox 6.0 RC2(!) and initially activating the Wifi it worked once. So I am pretty sure that there is a solution for my problem :). But as soon as I reboot the system I am no longer able to connect. Now I have updated to RC3 an the Wifi never connect (not even the first time as it did in RC2)
      Initially ifconfig listed me my wlan0 with IP (in RC2), but after a reboot checking ifConfig, wlan0 is no longer listed. Using "ifconfig wlan0 up" starts the wifi but after a reboot it is disabled again.
      What I have done so far:
      Enabling the wifi via the GUI.
      Adding Wifi information manually in the recalbox.conf (with and without static ip + mask etc..).
      Any help would be appreciated.
