    No XBOX360 Controller Support!?
    GamePad/GPIO/USB encoder
    xbox360 support
    1805
    • Akabar
      Akabar last edited by
      Hello,
      i installed Libreelec and Recalbox with the Pinn Installer (Fork of Noobs).
      But in recalbox i dont see any option to use / Activate the xbox 360 wireless controller.
      I looked also at the Webinterface via http://recalbox.local/
      At the recalbox.conf is nothing inside, having anything to do with xbox...
      Also the Tab Controller doesn´t contain the Part Xbox360.
      Is there any way to add Support for the XBOX 360 Wireless Controller?
      I Use the orginal Microsoft Receiver
      Thanks, Julian
      • Bkg2k
        Bkg2k Staff last edited by
        There is nothing to do The x360 is supported out-of-the-box.
        I'm using one wired x360 controler and 2 wireless x360 with microsoft receiver without any issue.
        • Akabar
          Akabar last edited by Akabar
          So i downloaded the 6.0 RC3 and tried to flash it on my pi 3b+ via the tool Etcher.
          But at Boot time i get a Kernel Panic and nothing works.
          But i opend the .img on my Windows pc and looked in the recalbox.conf and there is also nothing in it with the Xbox360 controller.
          Does the Version 6.0 support xbox 360 controller yet at all?
          MikaXII 1 Reply Last reply Reply Quote 0
          • Bkg2k
            Did you read my previous message?
            • MikaXII
              MikaXII Staff @Akabar last edited by
              @akabar Bkg2k says :
              So just plug your xbox360 controller.
              For your kernel Panic try another tools or use a sandisk µsd card if its not the case yet
              mika@recalbox.com
              • Akabar
                i Pluged it in several times with the with the v6.0 rc2 and it doesnt work. Pressed the sync button on the receiver and at the controller also. No reaction in Recalbox.
                So not working out of the box for me 😞
                I tested it with 2 different controllers. Both work fine on my xbox 360.
                100.9k
