    Amiga controllers not working
    Emulator Arcade/PC/Console
    amiga
    • chris72
      chris72 last edited by
      I have a Competion USB and a PS2 controller both do not work with the Amiberry emulator. In the Amiberry configuration I can set what I want, the only thing that works is the fire button. In the other emulators (C64, Atari, NES and so on) these controllers work fine.
      Can anyone help me?
        Hello @chris72
        can you post your archive support, please, after launch a amiga game for @Bkg2k
        http://recalbox/help (windows) or http://recalbox.local/help (MacOS)
        chris72 1 Reply Last reply Reply Quote 0
        • chris72
          chris72 @acris last edited by
          @acris @Bkg2k
          Thanks for your support. The file can be downloaded here: recalbox-support.sh
          I started recalbox, then directly started a WHDL game (Great Giana Sisters), pressed the fire button once. Press the left button to start the game, but nothing happens.
          I hope you can help me.
          Dante 0 1 Reply Last reply Reply Quote 0
          • Dante 0
            Dante 0 @chris72 last edited by Dante 0
            @chris72 I have the same Problem. It´s just the fire Button wich works fine....sometimes! Woud be great if you can help!
            • chris72
              My controllers are working now, but has nothing to do with the RC3. I found out the following by trying it out. It was just a setting that you can't change in Amiberry's GUI. Here's what I've done now:
              In the folder /recalbox/share/roms/amiga1200 I created a file named .uaeconfig.uae
              IMPORTANT is the POINT in front of it, otherwise the file will not be loaded!!!
              In this file I have only two lines in it, which will be overwritten by the default configuration:
              show_leds=false
              amiberry.use_analogue_remap=false
              The use_analogue_remap is normally set to true and therefore my PS2 controller or CompetitionPRO didn't work.
              Maybe this will help others too!
              101.4k
