    Unsolved Universal xml scraper broke recalbox
    Emulator Arcade/PC/Console
    broke recalbox
    1465
    • Bas
      Bas last edited by
      Hi,
      I’ve used universal xml scraper and ‘killed’ emu station by the app.... it literally did!!
      Recalbox plays the random console animated on start up and then stuck black screen with recalbox build number...
      How do I restore it to go into emustation?
      After scraping something must be messed up but what is it?
      I can still acces recalbox from network on my pc.
      Any ideas before reinstalls recalbox?
      Help Much appreciated 🙂
        paradadf Staff @Bas last edited by
        @bas as you can access your recalbox, just open the web manager, go into the support tab and (re-)start Emulationstation from there.
        Bas 3 Replies Last reply Reply Quote 0
        • Bas
          Bas @paradadf last edited by
          @paradadf
          Don’t mind my noob ness but how do you mean restart from web?
          On my PC I can only access the Share directory, followed by Roms, System etc.
          How do you restart ES from webacces?
          Thanks this would be awesome.
          • Bas
            @paradadf
            I’ve found the tutorial how to acces :-))
            How do I repair it?
            • Bas
              @paradadf
              Nevermind.
              I just needed to reed your post...
              Go into support tab.... 🙂
              • Bas
                Bas last edited by
                No Web manager didn;t work.
                Re-flashing recalbox and copying Roms 🙂
                101.4k
