    How to saving retroArch Configuration File?
    Emulator Arcade/PC/Console
    saving retroarch file
    • rizzie
      rizzie last edited by rizzie
      Hello.
      I'm using recalbox 6.0.0 RC1 on rp3b. I entered the Retroarch configuration by pressing the hotkey + b button in Neogeo(Fbalpha core) and I change mvs to unibios on bios. but this is not saving. I had to change it every time this. recalbox 17.07.18 was save the change bios. How to save the retroarch configure? Thanks a lot.
        Hello
        it's a bug, fix in RC-2
        The RC2 is approaching quickly.
        Here is what has been fixed since the RC1:
        Fix default GBA games metadata
        Fix old core names in recalbox.conf (automatically renamed)
        Add Ximo controller to pre-configured pads/joyticks
        Fix missing desmume_libretro.so
        Fix reicast on XU4/X86
        Fix virtual gamepad
        Fix device handling to quit demo mode
        Fix Kodi not starting with some gamepad
        Fix retroarch core options not saved
        Fix AROS bios with CD32
        Fix Oricutron conflicts between 2nd player joystick and keyboard
        Fix Dragonrise on Amiga (partially, you still need to HK+B and reset the emulator)
        Fix descending sorts in gamelists
        Improve randomness in demo mode
        Here is what WILL NOT be fixed until the final release:
        AdvanceMame configuration not saved (need some code rework and appropriate tests)
        The internal scraper is not reliable (need some heavy code rework)
        You can still reports bugs not listed here, we'll do our best to fix them before the finale
        rizzie 1 Reply Last reply Reply Quote 0
        • rizzie
          rizzie @acris last edited by
          @acris Thanks so much~ Have a nice day~
