    Solved Recalbox 6.0 RC 1 Bugs
    recalbox 6.0
    • fosi
      fosi last edited by fosi
      Hello
      i use a raspberry 3B+ and i flash the new image 6.0 Rc1
      I use 128 Gb Card.
      1.scraping dont work at all.
      2. If i want to change in retroarch the Unibios for Neo Geo instead MVS the unibios start but only once it dont save the settings!
      regards fosi
        Hello
        the scrap is buggy. It will be correct in the next update.
        There is a problem with the cores options, also correct for the next update.
        thank a lot for your feedback.
