    Retroarch changes are not saving for all roms
    retroarch changes are saving roms
    • jorgemagana
      jorgemagana last edited by
      Hello, I made a fresh install of the Release Candidate versión, and I found a problem with Retroarch:
      In MAME2003 for example, with previous beta version of Recalbox if I enabled skip warnings and disclaimers, that configuration remained for all the roms, but now not.
      Same thing happens with PSX Retroarch configuration, if I enable, for example, the enhaced resolution, now this remains only for the rom where I actívate Retroarch pressing Hotkey+B, not for all roms.
      Do you know if now I have to actívate something first to keep the changes for all roms, not one by one?
      I am using a Rasp 3b+ and a USB key for roms. Thanks.
        Hello @jorgemagana
        Usb storage for your roms ?
        jorgemagana 1 Reply Last reply Reply Quote 0
        • jorgemagana
          jorgemagana @acris last edited by
          @acris yes
            @jorgemagana
            Rename retroarchcustom.cfg in retroarchcustom.cfg.old and reboot.
            Try again sorry for my english. I use google translate 😉
            • jorgemagana
              @acris ok I wil try it. Thanks
