    GPIO support in non-raspberrypi
    GamePad/GPIO/USB encoder
    gpio non-raspberrypi
    • dh04000
      dh04000 last edited by
      Does Recalbox have support for GPIO in any other platforms, XU2, C1/C2, Rockboard, x86?
      • ian57
        ian57 Staff last edited by
        @dh04000 no, for now only the Raspberry Pi GPIO is supported.
        dh04000 1 Reply Last reply Reply Quote 1
        • dh04000
          dh04000 @ian57 last edited by
          @ian57
          I found a version of wiringpi ported to odriod boards, if that helps. https://wiki.odroid.com/odroid-xu4/application_note/gpio/wiringpi
          • ian57
            @dh04000 of course wiringPi is ported on odroid, but Recalbox doean not use it for GPIO controller. We are using un kernel module, so it has to be rewritten to match odroid's GPIO.
            • dh04000
              @ian57 said in GPIO support in non-raspberrypi:
              Darn, sounds like it would be serious trouble to implement.
              Recently I have grown tired of the Pi's limitations and slow hardware releases, and have cosidered moving to a stronger hardware platform, but my use case depends on GPIO access.
              Any suggestion on how i can implement this(https://github.com/recalbox/recalbox-os/wiki/Emulator-interactions-via-GPIO-mapping-(EN)) without GPIO access?
              Thank you.
