    Wii - Gamecube : Games Lagging.
    wii gamecube lagging
    • TriaH_
      TriaH_ last edited by
      Hi! So i've made a Recalbox using an old laptop from 2015. Everything works fine, all the consoles work at a steady 60 fps. But Wii and Gamecube games are unplayable. I have audio stuttering, bad fps (around 25 - 30), general lag. I want to know if there is a way to improve the performance of these games, becouse my computer is not that bad, i played AAA titles with it and no stutter and no lag. Am i missing something? Help!
      I'll copy here the specs of my laptop :
      Intel core-i7 3770
      Nvidia Geforce gt 640m with 2Gb
      8 Gb of DDR3 ram
      1 Tb of HDD
      the display is 1366x768 pixels
      strodown 1 Reply Last reply Reply Quote 0
      • strodown
        strodown @TriaH_ last edited by
        hi @triah_ I advise you to test this version that supports NVIDIA proprietary drivers
        https://forum.recalbox.com/topic/15914/recalbox-pc-x86_64-avec-les-drivers-nvidia
        Recalbox X86_64 :
        X-Arcade
        Lightgun Mayflash Dolphin-bar
        • TriaH_
          Thanks for help! But unfortunately it didn't work... well i can't even play anything, becouse when i load it up, the main menu of the Recalbox is veeeeeeeery slow, like 2 fps. I downloaded it again and reflashed with Etcher, but it didn't also work.
          am i missing some installation steps for this particular version of recalbox?
          • strodown
            @triah_ the new version does all the work automatically, however, it has problems with share and other recordings on a usb support
            I recommend you to flash this version with a hard disk and then put it in place of the internal hard disk
            it's not very practical but you can be sure that it will work
            Recalbox X86_64 :
            X-Arcade
