    RPI0 External usb sound card is not showing up in volume/sound output menu.
    rpi0 external usb sound card
    1961
    • Zuny
      Zuny last edited by
      Hi! I've recently bought this type of usb sound card: https://imgur.com/a/dd3y2Ha and I was wondering how I can make it work 🙂
        Hello @Zuny
        Try to go sound option.
        • Zuny
          Zuny last edited by Zuny
          @acris tried already only gives me auto, hdmi and jack
            voljega Banned @Zuny last edited by
            @zuny try to select it in Kodi
            Zuny 1 Reply Last reply Reply Quote 0
            • Zuny
              Zuny @voljega last edited by
              @voljega it's not showing and there
              • Zuny
                Zuny last edited by
                anyways i will burn again and update it and let you know if it worked.
                • Zuny
                  Zuny last edited by
                  Seems like it's not working for now, if someone knows a variant of fix plz reply to the thread 🙂
                    Try to find on forum
                    Alsa mixer audio usb
                    • Zuny
                      Zuny last edited by
                      Seems like it's not even detecting it tried variety of commands such as: alsamixer (to check it) tried to edit the alsa (it got my recalbox broken and had to format my sd card and burn it again) also tried to "cat /proc/asound/cards" without success, on Windows (for sure) it worked and also played some music and stuff.
                      If theres else suggestions I will be more than happy to try them
                        Strange. Please post archive support
