    Retrolink N64 Controller Clone
    GamePad/GPIO/USB encoder
    retrolink n64 clone
    • mac321
      mac321 last edited by
      Hi all, I figured out that the configuration of the D-Pad for this controller is wrong in /usr/share/mupen64plus/InputAutoCfg.ini I have to use this: DPad R = hat(0 Right) DPad L = hat(0 Left) DPad D = hat(0 Down) DPad U = hat(0 Up) Instead of: DPad R = axis(5+) DPad L = axis(5-) DPad D = axis(6+) DPad U = axis(6-)   Maybe this also helps someone else.
        Hello thank a lot for your feedback, for recalbox 3.3.0 ? or recalbox 3.2.11 ? can you put on this forum your complete InputAutoCfg.ini ?
        • mac321
          Hi, its version 3.3.0.
            Thanks I'll look that on the beta release.
