    Recalbox on Waveshare game hat
    Your recalbox
    recalbox waveshare hat
    • cheungbx
      cheungbx last edited by
      I made a recalbox using Raspberry Pi 3B and waveshare game hat.
      See this youtube video
      https://www.youtube.com/watch?v=ijM91OzCvNI&t=3s
      Figured out how to map the GPIO pins on the waveshare game hatRecalbox on waveshare game hat
      Download the Recalbox 2018 12 24 Xmas beta boot image for Respberry Pi 3B+
      https://forum.recalbox.com/topic/1501...
      Recalbox config Parameters to adjust to make the Game Hat GPIO work:
      mount -o remount, rw /
      cd ~
      vi recalbox.conf
      then change the following
      system.power.switch=PIN56PUSH
      controllers.gpio.enabled=1
      controllers.gpio.arg=map=4 gpio=5,6,13,19,21,4,26,12,23,20,16,18,-1
      kodi.enabled=1
      kodi.atstartup=0
      kodi.xbutton=1
      wifi.enabled=1
      wifi.ssid=yuourssid
      wifi.key=yourpassword
      The boot up script file of the recalbox 2018 Xmas beta (/recalbox/scripts/recalbox-config.sh) cannot take in the second parameter I put into the recalbox.conf file.
      Until this is fixed in a later release, we need to change the following lines to fix this issue so the custom GPIO button pin mapping can take effect.
      vi /recalbox/scripts/recalbox-config.sh
      While in Vi Search for the line with extra2=“$4” using the command /extra2=“ , then press ENTER and a to add a line after it.
      extra3=“$5”
      Then Search for the line with map="$extra2” using the command /map=“
      Then change it to
      map="$extra2 $extra3”
      After that, reboot the recall box to take effect of the changes by typing
      shutdown –r now
      cheungbx 1 Reply Last reply Reply Quote 1
      • cheungbx
        cheungbx @cheungbx last edited by
        @cheungbx
        The previous Video link has been deleted.
        Pls view the youtube video here.
        https://www.youtube.com/watch?v=FWdlv_c1_6k&t=78s
