    Amiga Emulator installieren
    Emulatoren Arcade/PC/Konsole
    amiga installieren
    5670
    • lordaldi
      lordaldi last edited by
      Hallo,
      die Installation eines Amiga Emulators funktioniert nicht. Kann mir jemand helfen??
      Was ich bislang getan habe:
      Kickstart 1.3 runtergeladen
      MD5 überprüft -> 82a21c1890cae844b3df741f2762d48d
      Datei in kick13.rom umbenannt
      kick13.rom in den Ordner \RECALBOX\share\bios\ kopiert
      Hier gehts nicht weiter... Es erscheint kein ROM Verzeichnis wo man .ADF Dateien hineinkopieren könnte.
      Bin für Ratschläge dankbar!!
        voljega Banned @lordaldi last edited by voljega
        @lordaldi if you only have this bios your roms must be in amiga600 folder.
        Also name of the file must be every thing lowercase
        lordaldi 1 Reply Last reply Reply Quote 0
        • lordaldi
          lordaldi @voljega last edited by
          @voljega That´s not working. There was no such folder in the rom folder, so I have added this by my own. I have copied an .ADF file into amiga600 folder, but nothing happens.
          Furthermore there is no kick13.rom, or any other ROM in the BIOS list that is named 82a21c1890cae844b3df741f2762d48d
            @lordaldi so you are on Pc or Odroid and Amiga is not available for it, only for pi 2,3 and 3b+
            • lordaldi
              @voljega I´m on pi 3b+ with recalbox
              when I put the kick13.rom file into the web app (recalbox/bios) it´s getting verified with a hook, but I can´t find a ROM file.
                @lordaldi if you added rom folder by hand, it's not normal, it should already be created.
                I don't understand what you say when you say you can't find rom, you should add and use adf
                • lordaldi
                  @voljega the installation of the rom folder by hand was an attempt because I don´t get an Amiga folder after installing the kick13.rom
                    @lordaldi one has nothing to do with the other at all.
                    Did you have an amiga600 and amiga1200 folder in roms folder or not ?
                    In bios folder you should alsp have an amiga folder beforehand
                    • lordaldi
                      @voljega I don´t have any Amiga folder. Not in roms folder, not in bios folder
                        paradadf Staff @lordaldi last edited by
                        @lordaldi which recalbox version (exactly) do you have?
                        • lordaldi
                          lordaldi @paradadf last edited by
                          @paradadf its version 4.1.0
                            @lordaldi it is impossible to install an ancient version like 4.1 on the pi3b+.
                            • lordaldi
                              @paradadf said in Amiga Emulator installieren:
                              Sorry its a RPI 3 Model B version 1.2. Not a plus
                                @lordaldi install last official version then, amiga emulation didn't exist on 4.1
                                • lordaldi
                                  lordaldi @voljega last edited by lordaldi
                                  @voljega is 4.0.1 the offical version? I have installed this version now, but after the attempt to install the amiga emulation by pulling the kick13.rom into the bios I´ve got the failure message that this bios file is not supported.
                                    @lordaldi no 4.0.1 is a very old one.
                                    https://archive.recalbox.com/
