    Gamelist.xml generates itself in a "corrupted" state
    gamelist.xml generates itself corrupted state
    • boxcarpilot
      boxcarpilot last edited by
      Hi,
      Version: 18.06.27
      Raspberry Pi3B
      I am unable to scrape PSX games, because my gamelist.xml is always 1KB.
      This is not happening with any other system.
      If I delete it, it will create a new one, but with 1KB, is that normal?
      I can't remember if gamelist is empty by default..... but think gamelist.xml is being generated corrupted.
      These are the contents of a brand new Gamelist file:
      <?xml version="1.0"?>
      <gameList />
      alt text
      Shouldn't be more like:
      <gameList>
      </gameList>
      I tried killing ES and manually editing the file with nano, when I save it and reboot, it goes back to it's initial state.
      alt text
        voljega Banned @boxcarpilot last edited by
        @boxcarpilot no it's a perfectly legit empty gamelist.xml
        • boxcarpilot
          boxcarpilot last edited by boxcarpilot
          Solved it seems universal scraper wasn't properly killing ES, after using /etc/init.d/S31emulationstation stop, I was able to scrape just fine
