    Rice core for mupen64
    Emulator Arcade/PC/Console
    rice core mupen64
    • TobyRieper
      TobyRieper last edited by
      Hey folks anyone know how to select the Rice core for N64? I've got a choice of gliden64 and gliden64mk2. I've tried swapping from default, going to advanced emulation settings etc
        paradadf Staff @TobyRieper last edited by
        @tobyrieper on what board? Usually, if it isn’t listed under the options means it isn’t available, at this moment at least.
        TobyRieper 1 Reply Last reply Reply Quote 1
        • TobyRieper
          TobyRieper @paradadf last edited by TobyRieper
          @paradadf odroid Xu4. Please don't tell me I've been searching for hours for something that doesn't exist
          Last question for you my friend... In my gliden64 log it says... depth compare and depth based fig will not work without image texture support provided in Open) 4.3 or Gles 3.1
          Each time I open the emulator. This something's I need to worry about? Thank you
            @tobyrieper you should not worry, as there is nothing you can do if your hardware, in your case xu4, doesn’t support those versions.
