    Solved Add music. Not replace
    music replace
    • aerao
      aerao last edited by
      Sorry, for several hours, I'm search but I can't find how to do, forum, wiki ...
      Is it possible to add music with those already existing in recalbo ? I don't want to replace them, just add.
      Thx a lot!
        paradadf Staff @aerao last edited by paradadf
        @aerao there is a music folder inside the theme. But you can also use this wiki:
        https://github.com/recalbox/recalbox-os/wiki/Add-Custom-Music-to-EmulationStation-(EN)
        And about themes in general:
        https://github.com/recalbox/recalbox-os/wiki/Add-emulationstation-themes-(EN)
        • aerao
          aerao last edited by aerao
          @paradadf I already read the first link, but when I add my music it replaces the other music from recalbox.
          But.....
          Yes, Thx :
          in your last link (I DL recalbox-themes-master.zip), and i found a music folder, with all the recalbox theme music (recalbox-themes-master \ themes \ recalbox \ music).
          I will be able to take them and add them in the music folder of my usb key with my playlist.
          That's works fine.
          Big Thx!
          100.9k
