    Solved Secret of Evermore and black screens
    Emulator Arcade/PC/Console
    secret evermore screens
    • Edenlegaia
      Edenlegaia last edited by
      Hi all!
      Well.....the title says a lot already, but here's what's going on. Changing screens can sometimes make a black screen occur. I remember having the same problem years ago when i tried playing it on the ZSNES emulator. I tried to get other roms, but it changed nothing back then, then simply used another emulator. It ran smoothly on Snes9x.
      So, i used the same rom to play it on Recalbox, to get the feeling of my good old (and lost..."sob") SNES game. Yet, i found myself stuck with a black screen the same way it happened on ZSNES.
      Does someone else have (had?) that problem? If so, was there a way to solve it?
        paradadf Staff @Edenlegaia last edited by
        @edenlegaia on what platform are you using recalbox?
        Have you tried different cores?
        Edenlegaia 1 Reply Last reply Reply Quote 0
        • Edenlegaia
          Edenlegaia @paradadf last edited by Edenlegaia
          @paradadf I'm playing it on a Raspberry Pi 3. I had no core installed. Immediately after reading your comment (and realizing i could install cores.....durr!) i tried the snes9x2010 one.
          I've been playing for twenty minutes and non stop changing screens without a single issue so far! I'll edit if something occurs but man, your comment saved the day! Thanks for the info!
            @edenlegaia good, but you didn’t install a core, you just changed it. Good play!
