    Help... Load your roms from a network shared folder
    help roms network shared
    • moguai
      moguai last edited by moguai
      Hi,
      in the wiki (EN) is an instruction how to load roms and saves from an network shared folder but I don't understand the instruction:
      https://github.com/recalbox/recalbox-os/wiki/Load-your-roms-from-a-network-shared-folder-(EN)
      I installed the beta 2018-11-13 with 3B+ Support on my Pi 3B+.
      I finished:
      • mount -o remount,rw /boot
      • edit the file /boot/recalbox-boot.conf ==> sharedevice=NETWORK
      But where I have to insert this:
      sharenetwork_smb1=ROMS@192.168.178.1:recalbox/share(right?)/roms:username=recalbox,password=Recalbox
      Also in the /boot/recalbox-boot.conf at the next line? Or simply in the command (SSH connection with JuiceSSH)?
      I tried both and I don't get connection.
      This is my configuration at the shared folder:
      Shared folder with this user starts at path:
      recalbox
      ----- than shared
      ---------------- than roms or saves
      2nd question:
      Could I still use with this configuration (if that would works) a usb stick that is syncronised with the sd card like in this instruction:
      https://github.com/recalbox/recalbox-os/wiki/Use-an-external-usb-storage-device-on-recalbox-(EN)
      Or have I decide for the shared network folder or usb stick sync?
      Thanks for help
      Sven
      Rpi3 B+
      PS3 Dualshock, XBox 360 wired
      • Bkg2k
        Bkg2k Staff last edited by Bkg2k
        Your /boot/recalbox-boot.conf should contain:
        sharedevice=NETWORK
        sharenetwork_smb1=ROMS@192.168.1.21:roms:username=*****,password=*****
        Where:
        • roms (right after the IP) is a root SMB shared folder. From W10, it can be accessed with \\192.168.1.21\roms
        • moguai
          Thank you for your reply, now I know where I have to insert sharenetwork_smb1=ROMS............
          Just for understanding:
          The wiki tells me that I have to copy the same directory structure like on the sd card (/recalbox/share/roms). I did it like this way.
          That's why I added a ftp user that starts in the shared folder where I see the recalbox folder.
          Is this correct?
          Or could I use 192.168.xxx.xxx:roms: like that path?
          So, this picture of folder "share" is ftp user root, if I use :roms: in
          sharenetwork_smb1=ROMS@192.168.xxx.xxx:roms:username=*****,password=*****?
          And any idea to my:
          2nd question:
          Rpi3 B+
          • toniosj
            toniosj Spanish moderator last edited by toniosj
            Same NAS, same file recalbox-boot.conf on Stable Recalbox and Beta Recalbox, and beta doesnt detect Shared folder. On Stable recalbox works fine. Some must could be changed on beta version.
            EDIT: I solved it adding ,vers=1.0
            Try sharenetwork_smb1=ROMS@192.168.178.1:recalbox/roms:username=recalbox,password=Recalbox,vers=1.0
