    recalbox on emmc drive
    recalbox emmc
    • limix429
      limix429 last edited by
      Hi,
      I try to install recalbox on my HP stream 11 (emmc 32 gb), so i boot on xubuntu live i do a dd if=recalbox.img of=/my/emmc
      When dd is ok, i reboot the hp stream end i have an error after a few seconds :
      mount : mounting LABEL=RECALBOX on /new_root failed : No such file or directory.
      Can i fix this or i have to give up this idea to transform my hp Stream to a recalbox ?
      Thanks
      • Quemandoacromo
        Quemandoacromo last edited by
        @limix429 Boot Linux from pendrive,download and run Etcher then install the image to your eMMC using Etcher.
        limix429 1 Reply Last reply Reply Quote 0
        • limix429
          limix429 @Quemandoacromo last edited by
          @quemandoacromo i try it, same result. Etcher do the same that a dd do i think.
            Zing Global moderator Translator @limix429 last edited by
            @limix429 Are you booting in UEFI or LEGACY ?
