    Unplayable Raspberry 3
    unplayable
    2175
    • EniD
      EniD last edited by
      Hello I am using recalbox last version on Raspberry Pi 3B v1.2.
      And its unplayable all my actions on controller are done slowly.
      For example on MarioWorld (super nintendo) when I press jump mario jumps like 1 second after I pressed the button.
      I thought it was the controller so I tried it on my odroid xu4 and it works perfectly and its the same on my computer with the same rom.
      I don't get why it doesnt seem that the rpi is at 100% usage cause except my action all is displayed correctly.
      I activated FPS monitor and I run near 60fps every time.
      So I don't know what can I do ?
      Thanks for your help
        Zing Global moderator Translator @EniD last edited by
        @enid Hello!
        Did you even create the Recalbox image, or downloaded a ready-made image? Are you using which version of Recalbox?
        • RustyMG
          RustyMG last edited by RustyMG
          I thought Recalbox doesn't work on the Pi3B? (apart from the experimental beta release thats still being worked on).
          And you say "Recalbox last version" - exactly what version are you running?
          Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
            Zing Global moderator Translator @RustyMG last edited by
            @rustymg Recalbox works on Rpi3, with an official version, a long time ago. The beta version is for Rpi3 +.
            RustyMG 1 Reply Last reply Reply Quote 0
            • RustyMG
              RustyMG @Zing last edited by
              @zing Sorry my bad!
              I was just asking the OP to clarify his set up in case he was actually using the new and incompatible Pi3B+
              • EniD
                EniD last edited by EniD
                Hello all thanks for answers !
                https://archive.recalbox.com/ downloaded the rpi3 version good link its hard to fail this.
                When I launched the rpi it said 18.07.13 all working well except "playing".
                After the download I used echter.
                Its a sandisk 32gb class 10 : https://www.amazon.com/Sandisk-Ultra-Micro-UHS-I-Adapter/dp/B073JWXGNT/ref=sr_1_4?ie=UTF8&qid=1541535814&sr=8-4&keywords=sandisk+32gb++class+10&dpID=41o%252BsCWxP2L&preST=SY300_QL70&dpSrc=srch
                Please note I tried on odroid which is the same process I think, and I didnt meet any problem.
                  @enid Have you tried mapping the joystick? Have you tried with another joystick? Have you tried with a keyboard?
                  Does this happen in 1 single game? In a single emulator?
                  When you recorded the official image, how did you transfer the ROMS to this new image? I mean, if you use the clean image, and add only the SNES Super Mario World rom, does it work the same way?
                  I'm assuming that if you transfer a backup of the entire SHARE folder to the new image, maybe some old configuration file is the problem, I do not know if that's the case, it's just a guess (since you made it clear that you already use Recalbox on the other devices).
                  101.0k
