    RecalBox not working properly
    recalbox properly
    • JimyBassy
      JimyBassy last edited by
      So I´ve got recalbox on a USB installed in order to use it on my laptop, the issue here is that after booting correctly ANY ROM that I open just makes the computer freeze and I have to restart it.
      Things that I´ve tried:
      -Reinstall it several times
      -Try different USB´s
      -Try different images of this software
      -Try my own ROMs
      Nothing has changed yet hope you guys can help me!!!
      Thx
      DJMatrix-HU3 1 Reply Last reply Reply Quote 0
      • DJMatrix-HU3
        DJMatrix-HU3 @JimyBassy last edited by
        @jimybassy Specify make and model of your laptop maybe recalbox drivers are not compatible with it
        • mattmame
          mattmame last edited by
          Hi,
          Can you test your key on another computer ?
          If that works, thé problem may be your computer
          Si vous avez aimé mon post ou s’il a pu vous aider, mettez moi une petite flèche vers le haut.
          • tonificante
            tonificante last edited by
            Look for the file retroarchcustom.cfg and change the value of input_joypad_driver from udev to sdl2
            More info:
            https://forum.recalbox.com/topic/8125/4-1-slow-game-launch-any-game-emulator/35
