    Recalbox Rasberry pi 3 and Analog joystick
    Community projects
    recalbox rasberry analog joystick
    • hoangnganvy1993
      hoangnganvy1993 last edited by
      Anyone know of a good tutorial to add Analog joysticks and small 16 mm and 12 mm buttons pretty much like a StreetFighter ll cabinet. I would also like to add a 5 inch hdmi powered screen for it as well. I've searched and it either requires Arduino or some odd set up and needs a breadboard. I'm looking for a cleaner soloution and more plug and play.
      https://luanvan1080.com/viet-thue-luan-van.html
        voljega Banned @hoangnganvy1993 last edited by voljega
        @hoangnganvy1993 only thing cleaner I'm aware off would be to pull apart a xbox360 or ps3 controller and reuse the electronics board inside if possible.
        also be aware you won't be able to use recalbox at all with just analog joystick, the main interface for selecting games only works with digital pad
