    [sOLVED]fba-libretro instead of pi-fba
    • 0zzy
      0zzy last edited by
      Hi all, i'm here again! and im testing the 3.3.0 beta14 (its AMAZING!!) is it possibile to use fba-libretro instead of pi-fba for noegeo roms? (plz  don't suggest me to put neogeo roms on fba-libretro roms dir) 😄   tnx all!!!
      • tiwacs
        tiwacs last edited by
        Yes it is ! you have to change 2 lines in your recalbox.conf : (perhaps will you have to update the recalbox.conf first, using the recalbox.conf.template file in the same folder ) # ------------ I - EMULATORS CHOICES ----------- # from : ## NeoGeo emulator ## You can use pifba or a libretro core (fba2x,libretro) neogeo.emulator=fba2x ## If you set libretro as neogeo.emulator, uncomment the line below and set the retroarch core (fba,imame4all) ;neogeo.core=fba To : ## NeoGeo emulator ## You can use pifba or a libretro core (fba2x,libretro) neogeo.emulator=libretro ## If you set libretro as neogeo.emulator, uncomment the line below and set the retroarch core (fba,imame4all) neogeo.core=fba   Enjoy 😄
        • 0zzy
          0zzy last edited by
          Oh f..k! The main config file..sorry.. Tnx plop!
