    TV RESOLUTION PROBLEM
    tv resolution
    8514
    • usman_tahir880
      usman_tahir880 last edited by
      Hello Experts,
      I am newbie to Recalbox i have problem with resolution when i am connecting to my TV. However game is working fine. I don,t care about resolution on laptop. I just want to fix the resolution on tv.
      Note=TV is connected through HDMI cable.
      Please help me.screenshot is attached below.
      Sorry for bad english.
      Game running on laptop while connecting to TV.
      https://ibb.co/mRoArp
      Game running on TV.
      https://ibb.co/cQuTcU
      Recalbox emulation station menu on TV.
      https://ibb.co/fpCs49
      Recalbox emulationbstation menu on laptop.
      https://ibb.co/hzqej9
        Zing Global moderator Translator @usman_tahir880 last edited by
        @usman_tahir880 Hello!
        Read this topic:
        https://forum.recalbox.com/topic/14398/menu-and-kodi-is-not-full-screen-on-old-netbook/4
        • usman_tahir880
          @Zing
          When i am running xrandr this is showing screen shot attached.
          https://ibb.co/nqGNnU
            @usman_tahir880 Sorry, I've never had this problem, just know that some people have this problem and the gnubit user's instructions on the link I sent to you are very helpful.
            But, I saw that you're running the terminal through your cell phone, have you stopped the Emulationstation before?
            Since you are in a laptop, why not run the terminal directly from the laptop?
            https://github.com/recalbox/recalbox-os/wiki/Root-access-on-terminal-(EN)
            • usman_tahir880
              @Zing same issue through direct access
              So what you suggest should i check other laptop.
              Zing gnubit 2 Replies Last reply Reply Quote 0
                @usman_tahir880 Try this:
                https://github.com/recalbox/recalbox-os/wiki/Change-display-resolution-on-x86---x86_64
                • gnubit
                  gnubit @usman_tahir880 last edited by gnubit
                  @usman_tahir880
                  As @Zing has mentioned you will need to kill emulation station first, here is another thread which might help:
                  https://forum.recalbox.com/topic/14772/output-to-an-external-tv-via-hdmi-or-vga-doesn-t-appear-to-be-working-with-recalbox-installed-on-pc/11
                  • usman_tahir880
                    Atleat i figure out to run kodi in full screen see screenshot.
                    https://ibb.co/nCvnMp
                    I just accidentally press forward slash key.
                    https://ibb.co/j34iSU
                    I had also tried after kill emulation by pressing F4.
                    gnubit 1 Reply Last reply Reply Quote 0
                    • gnubit
                      @usman_tahir880
                      did you stop ES from root terminal from your laptop ?
                      /etc/init.d/S31emulationstation stop
                      then xrandr to list your displays
                      • usman_tahir880
                        @gnubit tried but same 😞
                        • usman_tahir880
                          I think it can be display driver issue because i had read some logs mentioned this.
                          HDMI1 mode not available.
                            @usman_tahir880 try the command:
                            DISPLAY=:0.0 xrandr
                            • usman_tahir880
                              @Zing same error can't open display
                                @usman_tahir880
                                Read this:
                                https://ubuntuforums.org/showthread.php?t=1947733
                                https://ubuntuforums.org/showthread.php?t=867506&page=2
                                https://wiki.ubuntu.com/X/Config/Resolution
                                I may be wrong, but from what I understand the problem is with "xorg.conf" (or its absence).
                                If so, these links will help:
                                https://fedoraproject.org/wiki/How_to_create_xorg.conf
                                https://askubuntu.com/questions/217758/how-to-make-an-xorg-conf-file
                                Read the information for all the links, and test the suggestions (make a backup of your image before, by security).
                                I do not have this problem, and I'm not a programmer, so I do not know the exact answer to your problem. So it is best that you test the options we are showing you, and give us feedback (positive or negative).
                                • usman_tahir880
                                  I have checked on other laptop same error coming.
                                  Cant open display
                                  Please helppp.
                                    @usman_tahir880 Did you read the links I posted ?? Have you tried the commands that the links suggest ??
                                    • usman_tahir880
                                      usman_tahir880 last edited by usman_tahir880
                                      @Zing Yes i have read but no luck 😞
                                        @usman_tahir880 Say everything you tried and what the result of each command, otherwise it is impossible to help you without knowing what happens. For example: What is the result of the "Xorg: 1 -configure" command? Have you tried this command already?
                                        • usman_tahir880
                                          @Zing i run this command.
                                          DISPLAY=:0 xrandr --listmonitors
                                          Here is the output.
                                          Monitors: 2
                                          0: +eDP1 1366/310x768/170+0+0 eDP1
                                          1: +HDMI1 1920/1600x1080/900+0+0 HDMI1
                                          • usman_tahir880
                                            I edit this file .xinitrc and enter this line
                                            xrandr --output eDP1 --off
                                            Now ES MENU IS ON FULL SCREEN BUT GAME IS NOT WORKING.
                                            101.4k
