    Moonlight Rpi3B+ 1080p 60fps
    Testers's corner
    moonlight rpi3b 1080p 60fps
    • eightkiller
      eightkiller last edited by
      Hy, I would like to know if someone has yet tested to run moonlight at 1080p and 60fps with the new rpi3 b+ ans recalbox ? If so, does it still have input lag with the controllers or is it now playable properly ? (with ethernet of course :p)
        Substring @eightkiller last edited by
        @eightkiller I haven't tried on 3b+, but i can definitely tell you that I never had any noticeable lag. But this means you play in 720p, 1080p is laggy.
        • eightkiller
          Yes that's why i'm asking if it changes anything on 1080p with the new 3b+ ^^, I'm playing DragonBall Fighter Z and it's not the same in 720p ^^. I have to find a solution to play it in 1080p without input lags. If you have some idea even with something else than recalbox 😛
