    cant find resolution.
    resoltion tv-lcd black screen
    2650
    • Gafdu
      Gafdu last edited by
      When i start the console it loads to the emulation station just fine. when i load a game the screen goes black and appears to change resolutions but it never finishes and it stays black and the game never appears on screen. i can drop back out to the emulation station without issue.
      if i press the info button on the tv remote i get info for the resolution and such. watching this i can see it change to a ton of different resolutions and frame rates. it even does weird settings like ##x0 or reverse. it finally settings and stops at 0x0. then i exit back to emulation station fine.
      i reinstalled the OS and it still does this. it currently has all default settings. i did not have to change any settings for first use previously. it had started at after a decent period of non-use. i imagine i installed any updated before anything else.
      i tested it on a second tv and the issue remained, and the emulation station displayed in a weird resolution.
      any advice?
      Zing Substring 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @Gafdu last edited by
        @gafdu You did not say what architecture you are using ... Rpi3? Rpi3 +? PC?
        Gafdu 1 Reply Last reply Reply Quote 0
        • mattmame
          mattmame last edited by
          Hello,
          Wich kind of game is it ?
          Original installed with Recalbox ?
          Added games ?
          Thanks
          Si vous avez aimé mon post ou s’il a pu vous aider, mettez moi une petite flèche vers le haut.
            Substring @Gafdu last edited by
            @gafdu if you're on a pi, Recalbox switches games to 720p. If your monitor doesn't support it, set global.videomode=default in recalbox.conf
            • Gafdu
              Gafdu @Zing last edited by
              I am using raspberry pi3 b.
              It happens for any added game. I have not attempted on any games pre-installed.
              I will make the change in the settings. When I have a chance I will make a list of things I have tried.
              mattmame 1 Reply Last reply Reply Quote 0
              • mattmame
                mattmame @Gafdu last edited by mattmame
                @gafdu may you try pre-installed games and tell us if it works.
                On wich system have you added games ?
                Some needs specific bios and games version like mame or fba.
                Did you put them on the good folder ?
                • Gafdu
                  Gafdu @mattmame last edited by
                  @mattmame
                  Initially the issue started for any game on any system under the same conditions for when it did function properly.
                  Since reinstalling I have only added NES and issue occurs.
                  Will attempt pre-installed games as soon as possible.
                  • Gafdu
                    without having changed any settings, and using the "info" button on the tv I can see the recalbox main menu displaying at 640x480, progressive, 60Hz, 4:3 aspect.
                    i can launch the game "Ura**s" on GBA. this game came preinstalled. it displays at 1920x1080, 30hZ, 1:9 aspect.
                    but now i have tried several games on different systems and they all work so far. all displaying with the same settings as mentioned above.
                    the only thing i have done is change the tv setting "auto aspect". it was annoying that every time the tv changed video, it tried to adjust the aspect ratio. so i finally disabled that. i tried games with that tv setting on and off and it worked consistently.
                    the global.videomode=CEA 5HDMI
                    global.ratio=auto
                    I really appreciate everyone trying to assist. but everything seems to be working fine and I have no idea why.
