    Dreamcast PS3 Controller issue
    GamePad/GPIO/USB encoder
    dreamcast ps3 issue
    2747
    • darth
      darth last edited by
      Hello, I have a problem with my PS3 controller on dreamcast.
      When I use the analog LEFT it goes to the right. If I use the analog UP it goes DOWN.
      This is a weird behavior because it only happens if I move the analog 100% to the left or up, but if I use it carefully, 80% of his moving capacity or less it doesn't go to the opposite direction. Besides if I use the controller connected with the USB cable it works great. It only happens with bluetooth connection.
      Is there any solution?
      Thank you.
      Substring joinski 2 Replies Last reply Reply Quote 0
        Substring @darth last edited by abunille
        @darth it's a known reicast problem, no solutions yet (try changing the driver to bluez)
        darth 1 Reply Last reply Reply Quote 0
        • joinski
          joinski @darth last edited by
          @darth
          remap your controller. this will fix it
          • darth
            darth @Substring last edited by
            @substring
            I have to use it with official driver, if I use bluez it does not recognize the controller over bluetooth.
            • darth
              darth @joinski last edited by
              @joinski
              I already tried that without success.
              joinski abunille 2 Replies Last reply Reply Quote 0
              • joinski
                @darth
                that's strange, because my original Sony PS3 Controllers (DualShock3 and Sixaxis) work fine in Dreamcast, when remapped before in ES Menu.
                • abunille
                  abunille @darth last edited by
                  @darth
                  On which Hardware you are? Odroid?
                  • darth
                    darth @abunille last edited by
                    @abunille said in Dreamcast PS3 Controller issue:
                    @darth
                    Raspberry Pi 3B
                    • abunille
                      abunille @darth last edited by abunille
                      @darth
                      Mmhhh, didnt see any problems to use bluez on pi3.
                      Try to forget bt controller via ES, change driver to bluez and reboot.
                      Reset your Controller.
                      After reboot try to connect on the standard way (connect via cable 10 seconds without pushing any buttons).
                      What Type of PS3 Controller do you have (Clone, genuine,...) ?
