    Main UI is cropped, but emulators work fine
    main cropped fine
    • T H
      T H last edited by
      Hi all,
      I installed Recalbox on my old AIO PC Compaq 100EU (display has resolution 1600x900). Everything works fine, but I have a problem with main Recalbox UI - screen is cropped as you can see on the picture.
      However, emulators and games work fine in fullscreen mode.
      I tried to check video config detailed, but I understood that these options are mostly for Raspberry - since I haven't found any boot/config.txt file. Am I correct?
      Do you have any ideas how to force fullscreen also in the main UI? It's annoying. Thank you!
      alt text
        Zing Global moderator Translator @T H last edited by
        @t-h Hello!
        Probably what you need to do is edit recalbox.conf and set the global.videomode to default:
        global.videomode = default
