    NETPLAY: Black Screen (Dont works)
    netplay dont
    3874
    • ToastMan
      ToastMan last edited by
      Hello!
      I trying to make work Netplay, i have the same rom, same hash, same core and all.
      But when i try to enter i get black screen for a coulple of minutes then says "Failed Netplay" and backs to the home screen.
      What im doing wrong?
      I have the same games and system and all, i just clones my sd, and put it in another Raspberry.
        Hello
        Check step in this post
        https://www.recalbox.com/blog/en/post/blog-2018-06-27-netplay
        Do you hash roms ?
        Rpi 3 ? Rj45 ? Join a recalbox player ? Host ?
        With recalbox player ?
        ToastMan 1 Reply Last reply Reply Quote 0
        • ToastMan
          ToastMan @acris last edited by ToastMan
          @acris
          I hash all roms
          RPi3
          When i host, i cant i get this error
          When i try to connect to another Host, i get the same error
          Recalbox Player with the Last Version. (Same Roms - Same Core - Same Hash) (I made a cloned image, to have all the same things configured)
          I have all games scrapped, i need to do that again?
          • joinski
            joinski last edited by
            Check if your internet-router has UPNP activated and/or the appropriate ports opened/forwarded.
            • ToastMan
              This is my Router Config. Its enabled.
              joinski 1 Reply Last reply Reply Quote 0
              • joinski
                joinski @ToastMan last edited by
                @toastman
                Use this tool, to check, if Netplay TCP Port (should usually be 55435, if I'm not mistaken) is open:
                http://www.yougetsignal.com/tools/open-ports/
