    Some arcade and MAME questions
    Emulator Arcade/PC/Console
    arcade mame
    • johnodon
      johnodon last edited by
      Hi all.
      I love that you can start RB on a specific system and turn off the system view. This is exactly what I want on my cabinet!
      Since my cabinet is dedicated to arcade only, I have two quick questions...
      1. Is there anyway to compile the current MAME Libretro core (0.200 as of this writing) on Recalbox or add it as an available emulator? Since I am running the x64 version, the limitations of the Rpi hardware are not an issue and I can run new versions.
      2. Will support for an 'arcade' system that supports multiple emulators ever be added? Or maybe this is possible today and I just can't find the answer. I would love to have a single folder and be able to put mame, fba, neogeo, daphne, etc. roms in it and call the appropriate emulator per game.
      Thanks,
      John
      • Gaetan
        Gaetan Theme moderator @johnodon last edited by
        @johnodon I don't know for the first question, but for the second, there is a way to have a custom es_system file where you can add you emulator. Then you'll need to have a custom theme to make it appear in ES.
