    Manette Nintendo 64 sur USB adapateur
    nintendo usb adapateur
    • core.entin
      core.entin last edited by
      je cherche à paramétrer une manette Nintendo 64 (originale) sur cet adaptateur USB
      ma config :
      Raspberry Pi model: 3B
      Recalbox version (build) : Build 81650228 from pipeline 25689355 based on 18.07.13
      Micro SD : SAMSUNG 32GB classe 10
      Power Supply: 3A
      Manette(s): Manette Nintendo 64
      USB adaptateur: USB GamePad USB GamePad
      j'ai donc suivit le A lire : Manettes N64
      donc voici le dmesg :
      [    4.225768] usb 1-1.3.2: New USB device found, idVendor=0079, idProduct=1879
      [    4.225782] usb 1-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      [    4.225789] usb 1-1.3.2: Product: USB GamePad
      [    4.225795] usb 1-1.3.2: Manufacturer: USB GamePad
      [    4.232474] input: USB GamePad USB GamePad as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:0079:1879.0005/input/input1
      [    4.232864] hid-generic 0003:0079:1879.0005: input,hidraw2: USB HID v1.10 Joystick [USB GamePad USB GamePad] on usb-3f980000.usb-1.3.2/input0
      [    4.238902] input: USB GamePad USB GamePad as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.1/0003:0079:1879.0006/input/input2
      [    4.239272] hid-generic 0003:0079:1879.0006: input,hidraw3: USB HID v1.10 Joystick [USB GamePad USB GamePad] on usb-3f980000.usb-1.3.2/input1
      le cat /proc/bus/input/devices :
      I: Bus=0003 Vendor=0079 Product=1879 Version=0110
      N: Name="USB GamePad USB GamePad"
      P: Phys=usb-3f980000.usb-1.3.2/input0
      S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:0079:1879.0005/input/input1
      U: Uniq=
      H: Handlers=js0 event1
      B: PROP=0
      B: EV=1b
      B: KEY=ffff 0 0 0 0 0 0 0 0 0
      B: ABS=30027
      B: MSC=10
      P: Phys=usb-3f980000.usb-1.3.2/input1
      S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.1/0003:0079:1879.0006/input/input2
      U: Uniq=
      H: Handlers=js1 event2
      B: PROP=0
      B: EV=1b
      B: ABS=30027
      B: MSC=10
      la commande jstest n'existe elle a été remplacé par sdl2-jstest donc j'ai voulus éditer le /recalbox/share/system/configs/mupen64/InputAutoCfg.ini comme suit :
      [^XUSB GamePad USB GamePad]
      plugged = True
      plugin = 2
      mouse = false
      AnalogDeadzone = 4096,4096
      AnalogPeak = 22350,22350
      DPad R = hat(1 Right)
      DPad L = hat(1 Left)
      DPad D = hat(1 Down)
      DPad U = hat(1 Up)
      Start = button(8)
      Z Trig = button(9)
      B Button = button(2)
      A Button = button(1)
      C Button R = button(1) <-- axe 3-
      C Button L = button(3) <-- axe 3+
      C Button D = button(2) <-- axe 2+
      C Button U = button(0) <-- axe 2-
      R Trig = button(7)
      L Trig = button(6)
      Mempak switch =
      Rumblepak =
      X Axis = axis(0-,0+)
      Y Axis = axis(1-,1+)
      mais je sais pas quoi mettre pour les C car ce sont des axes. Par exemple le sdl2-jstest -t 0 pour le C Button R :
      Joystick Name:   '^XUSB GamePad USB GamePad'
      Joystick Number: 0
      Axes  4:
         0:      0  [                                                        #                                                        ]
         1:      0  [                                                        #                                                        ]
         2:      0  [                                                        #                                                        ]
         3: -27055  [         #        ]
      Buttons 16:
         0: 0  [ ]
         1: 0  [ ]
         2: 0  [ ]
         3: 0  [ ]
         4: 0  [ ]
         5: 0  [ ]
         6: 0  [ ]
         7: 0  [ ]
         8: 0  [ ]
         9: 0  [ ]
        10: 0  [ ]
        11: 0  [ ]
        12: 0  [ ]
        13: 0  [ ]
        14: 0  [ ]
        15: 0  [ ]
      Hats  1:
         0: value: 0
        +-----+  up:    0
        |     |  down:  0
        |  O  |  left:  0
        |     |  right: 0
      B&ast;&ast;&ast;s  0:
      Est-ce que quelqu'un à une idée ?
      Par avance merci !
        archive de support à poster merci
        avec adaptateur branché uniquement
        et une autre avec adaptateur + manette
        • core.entin
          @acris said in Manette Nintendo 64 sur USB adapateur:
          https://file.ac/_pjelwxkqK4/
          https://file.ac/p12_YIXJ80g/
