    Xin mo setup on XU4
    GamePad/GPIO/USB encoder
    xin setup xu4
    2619
    • xMosssy
      xMosssy last edited by
      Hey everyone,
      I have been having a problem setting up my xinmo dual arcade with the latest release of recalbox on the XU4.
      The player one works perfectly but no matter what I do I have not been able to get the 2nd player detected. I have tried the fix found here:
      https://forum.recalbox.com/topic/13158/encodeur-usb-xin-mo-2-players-sur-odroid-xu4-ne-reconnait-qu-une-manette
      but it does not seem to work and I don't understand what they did after the OP said the first fix didn't work.
      Any help would be appreciated,
      Thank you
      Substring joss_baumont 2 Replies Last reply Reply Quote 0
        Substring @xMosssy last edited by
        @xmosssy hey
        It could be possible that the quirks were not properly configured for xu4
        • joss_baumont
          joss_baumont @xMosssy last edited by
          @xmosssy said in Xin mo setup on XU4:
          Hey everyone,
          Thank you
          Hello,
          The fix is correct, the good version is usbhid.quirks=0x16c0:0x05e1:0x040
          , that you have to add between the quote marks in the line :
          setenv bootargs "${bootrootfs} ${console}" (or something looking like that, I'm not at home to check)
          You have to wire the xin-mo exactly like that :
          https://github.com/recalbox/recalbox-os/wiki/Xin-mo-(FR)
          Recalbox 6.0
          Odroid XU4Q
            Xin mo devices have several ids, we have a few xinmo quirks around on pi thay should work on any other boars. Just have to enable usbhid as a moduld
            joss_baumont 1 Reply Last reply Reply Quote 0
            • joss_baumont
              joss_baumont @Substring last edited by
              @substring
              There are different IDs for original Xin-Mo boards? Arf, it's more complicated...
              I was lucky to have the same than in the quoted topic.
              Can we hope to have these modifications included in a next XU4 release?
              Thanks for all the work, by the way 🙂
              Recalbox 6.0
              Odroid XU4Q
                Substring @joss_baumont last edited by
                @joss_baumont i'll add it for the next release, yeah
                • joss_baumont
                  @substring
                  Great ! 🙂
                  Recalbox 6.0
                  Odroid XU4Q
