    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    922020
    • olivierdroid92
      @Bkg2k
      Board : XU4
      Image : Xmas 2018-12-24
      Micro SD Only
      Controller : Wired GameStop PS4 Fun Controller
      I've noticed the following issues.
      A-
      When go to advanced setting, and change core MAME from DEFAUT to ADVANCEDMAME --> Crash. With "restart ES" it works but not possible to activate 'ADVANCED MAME".
      B-
      When I want to play with MAME2010 (release 0.139) I do not have any folder /recalbox/share/bios/mame2010/ so I've created one to copy CHEAT.ZIP. I only have /recalbox/share/bios/mame2003/ folder
      Can be a good idea to create this folder to help newcomer 🙂
      C-
      In Web Manager, concerning Bios validation.
      I do not have no information neither green nor red cross with SCPH1001.BIN
      MD5 are OK
      Merci d'avance
      • Bkg2k
        Bkg2k Staff @olivierdroid92 last edited by
        @olivierdroid92 thanks for your report:
        A- Metadata are very buggy on the Christmas beta. Everything has been fixed for next betas/releases
        B- Easy improvement, validated 🙂
        C- Never seen that issue before. Did you try with another browser?
          voljega Banned @Bkg2k last edited by
          @bkg2k I also had this C issue ((always had it), I think it's related to case of the filename
          • olivierdroid92
            @Bkg2k @voljega
            using Google chrome on W10
            Case C
            Image 2018-07-13
            Bord RPI3B not +
            Screenshoot RPI3B - Microcard only, RJ45, wired pad
            No issue with scph1001.bin
            Image Xmas 2018-12-24
            Bord RPI3B not +
            Iissue with scph1001.bin
            --> When I change scph1001.bin to SCPH1001.BIN all was OK .
            Point C Solved
            • olivierdroid92
              @Bkg2k
              For MAME2003-PLUS (0.78)
              Cheat.dat file to be uploaded in : libretro system dir/mame2003-plus/
              so it will be /recalbox/share/bios/mame2003-plus/
              Same question : can this folder be created from the image ?
              • benjy51
                benjy51 last edited by benjy51
                @substring
                Bonjour:
                Pour ma part, sur odroid XU4:
                • probleme sur manette 8bitdo:
                  la premiere synchronisation: Ok . Puis, après plusieurs redémarages, les manettes sont oubliés, et on ne peux plus les associer.
                • problème pour changer la durée du splashscreen (les intro ne sont pas lu en entier malgré les modifications dans le fichier S02splash).
                Bon courage a l'équipe
                Odroid XU4
                Raspberry Pi 3B+
                • olivierdroid92
                  @benjy51
                  Maybe the threat in French can help you
                  https://forum.recalbox.com/topic/13471/odroid-xu4-8bitdo-sn30-pro-probleme-avec-bt
                  Try / essai
                  Méthode 2b
                  bluetoothctl
                  • olivierdroid92
                    @Bkg2k
                    Image : Xmas
                    Board XU4
                    RJ45
                    MicroSD card only
                    Wired pad
                    I played 1944 game on different MAME LIBRETRO cores : MAME0.78(2003) - MAME2003PLUS - MAME2010
                    Controls are not the same 😞
                    To be clear I have 3 full complete rom set.
                    Any chance to remap controls on core MAME2003 PLUS and MAME2010 based on MAME2003.
                    Controls configured for MAME2003 are the most usefull.
                      paradadf Staff @olivierdroid92 last edited by paradadf
                      @olivierdroid92 definitely not. That‘s something the core manages and for thousands of roms and different cores it is practically impossible to achieve.
                      • toto23
                        toto23 last edited by
                        Hello there!
                        First of all, thank you for all that work, u are awesome.
                        I just bought a a raspberry 3b+ and installed the beta on it. I found 2 issues:
                        • Favorites are not "remembered" when you reboot. Always forgotten by recalbox when you restart, even if you don't choose the fast shutdown.
                        • Moonlight seems to have a problem with the 3.16 version of Geforce. It's a known issue, that some programmers did solve by compiling again Moonlight with some code correction :lien vers github. But for those who are not familiar with coding, there is no available solution.
                          Thank u for reading this.
                        • phoenix887
                          phoenix887 last edited by phoenix887
                          Hello,
                          I want to play with 4:3 ratio, because for me, the only one solution, I dont like 16:9 at my retro games. That is the reason why I need overlays, it looks much nicer for me, without black space at the left and right side.
                          But it doesnt work. Here what I did:
                          snes.cfg
                          path: recalbox\share\system\configs\retroarch\snes.cfg
                          content of snes.cfg:
                          input_overlay = "/recalbox/share/system/configs/retroarch/overlays/snes_overlay.cfg"
                          snes_overlay.cfg
                          path: "/recalbox/share/system/configs/retroarch/overlays/snes_overlay.cfg"
                          content of snes_overlay.cfg:
                          overlays = "1"
                          overlay0_overlay = "snes.png"
                          overlay0_full_screen = "true"
                          overlay0_descs = "0"
                          Can anybody help me? where is the error? Or a Bug of the beta version of recalbox?
                          Thanks in advance
                          PS: Yes I know the manual: https://github.com/recalbox/recalbox-os/wiki/Retroarch-setup-overlays-(EN)
                          I did every step within the chapter Overlays by system
                          • Noojx
                            Noojx last edited by
                            Bonjour, tout d'abord bravo et merci au developpeur, je suis novice mais j'ai fais divers test, voici les bug que je rencontre sur la beta:
                            -Quand on switch entre audio HDMI a Jack, il y a un petit bug de navigation dans le menu
                            -Certains jeux ou emulateur : l'avance rapide fonctionne, mais pas le rembobinage.
                            -Sur Game and Watch avec le jeux en Multiscreen (donky Kong) plantage quand on saute. (ce n'est peut-être pas lié a la béta)
                            A vous de voir si ça vous est utile !
                            Bisous
                            • mantics
                              mantics last edited by
                              I downloaded the version from here but every time I start again it does not save the changes and I always have to reconfigure
                              lhari84 1 Reply Last reply Reply Quote 0
                              • lhari84
                                lhari84 @mantics last edited by
                                @mantics Do you mean changes of metadata (gamelists, favorites,...)?
                                In this case, just wait for new beta or final release.
                                It's a known issue and developers have written that it's even fixed already on their side but not released yet.
                                Pi 4:
                                Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
                                Pi Zero 2W:
                                GPi Case 2W, Recalbox 9.0
                                • mantics
                                  ok, thank you.
                                  tonificante 1 Reply Last reply Reply Quote 0
                                  • jorgemagana
                                    jorgemagana last edited by jorgemagana
                                    Hello. Excuse me if here it is not the place to post this.
                                    Could you please add the controller layout images for:
                                    Atari 5200
                                    Fairchild
                                    Intellivision
                                    WonderSwan Color
                                    The controller layout of rest of systems is very useful with kids. Thanks.
                                    • tonificante
                                      tonificante @mantics last edited by
                                      @mantics If you want to have something stable while waiting, then go for batocera. It is not so cool like recalbox but at least it is stable with pi3+ since a couple of releases. I think recalbox stable release for pi3+ will probably still take some time. Or if you want to help with the recalbox beta, then you are more than welcome to send here every bug you find 🙂
                                        paradadf Staff @jorgemagana last edited by
                                        @jorgemagana said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                                        Atari 5200
                                        Fairchild
                                        Intellivision
                                        WonderSwan Color
                                        Can you help us and add it?
                                        jorgemagana 1 Reply Last reply Reply Quote 0
                                        • jorgemagana
                                          jorgemagana @paradadf last edited by
                                          @paradadf I will try to do it!
                                          • cascav
                                            cascav last edited by
                                            Hello guys. Great job.
                                            I turn on christmas beta
                                            I do not arrives to running the roms Intellivision. Tested with different roms (different games, different format). Always black screen.
                                            Emulator problem? An idea?
                                            Thanks 😉
                                            Harko 1 Reply Last reply Reply Quote 0
