    Room screen off center
    room center
    2645
    • seb4usc
      seb4usc last edited by
      Hello, I'm haveing a problem with the emulator screen being off center bust the bootup menue pages and Kodi being perfectly fine, does anyone know how to fix it (see attached picture links)
      https://s.amsu.ng/Ag0I390uNkCN
      https://s.amsu.ng/0sLgqw8v73UN
      • seb4usc
        I mean emulator, sorry!
          Substring @seb4usc last edited by
          @seb4usc hi
          Can you give more details about your screen ?
          • seb4usc
            seb4usc last edited by seb4usc
            @Substring
            The screen I'm useing is a waveshare 7 inch 1024*600 as found here:
            https://www.amazon.com/dp/B015E8EDYQ/ref=cm_sw_r_cp_apa_3rWCBb3077YYS
            And I added the following text to the bottom of the config.txt
            max_usb_current=1
            hdmi_group=2
            hdmi_mode=87
            hdmi_cvt 1024 600 60 6 0 0 0
            hdmi_drive=1
            • seb4usc
              Is this thread still active???
              • Dragu
                Dragu Banned last edited by
                @seb4usc
                Try to add "hdmi_force_hotplug=1" in the config.txt. If it not helps, make nothing worse.
                seb4usc 1 Reply Last reply Reply Quote 0
                • seb4usc
                  seb4usc @Dragu last edited by
                  @dragu Thanks for the suggestion, I'll try it asap!
                  • seb4usc
                    That didn't work but thx for the idea
                    • Dragu
                      @seb4usc
                      It may just work by luck, as this screens are not supported by the standard, same problem in Retropie. You can find the documentation here :
                      https://github.com/raspberrypi/documentation/blob/master/configuration/config-txt/video.md#hdmi_mode
                      Now, you can always try out some things. For ES, it should be in /recalbox/share/system/recalbox.conf the line : global.videomode=default or to find a working way around with offsets. Not sure that it will work.
                      What else could help you, the descriptions in this config.txt
                      https://learn.adafruit.com/hdmi-uberguide/1303-pixel-qi-10-display-with-controller-1024x600
