    LED w/ Momentary Switch
    GamePad/GPIO/USB encoder
    led momentary switch
    • xtreemsurf
      xtreemsurf last edited by
      I've been successfully using a momentary switch with an LED for a while now, with config "system.power.switch=PIN356ONOFFRESET". I haven't updated since last year, and just ran an update last night.
      After the update, I can still switch the system on with the switch and the LED works, but I can't switch the system off with the switch. I tried replacing "system.power.switch=PIN356ONOFFRESET" with "system.power.switch=PIN56PUSH". This made the switch work perfectly for powering on/off, but now the LED doesn't turn on.
      Does anyone have a suggestion for this? Thanks so much!
        Substring @xtreemsurf last edited by
        @xtreemsurf most certainly you edited the script to get the led on ?
        xtreemsurf 1 Reply Last reply Reply Quote 0
        • xtreemsurf
          xtreemsurf @Substring last edited by
          @substring
          Are you referring to the config file? If so, yes, I edited the config file. I tried "system.power.switch=PIN356ONOFFRESET" and then "system.power.switch=PIN56PUSH". Is there are different script?
            @xtreemsurf no i'm referring to python files themselves
            • xtreemsurf
              The method described on this page (https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)) has always worked up until this update. Is editing the Python scripts necessary? If so, is there a guide for this? Thanks again!
