    Solved Noobs / recalbox yellow lightning
    MediaCenter & Dualboot
    3098
    • Sh_K
      Sh_K last edited by
      Hi,
      i hope i'm in the right section of the forum.
      i have some trouble with recalbox 4.1.0 and Noobs 2.8.
      Recalbox won't boot, a yellow lightning appears on th right top corner and nothing happens.
      I want use Noobs for dual boot Recalbox/Libreelec, Libreelec works fine, so i think it's not a problem of power supply (2A).
      I've tried to install Noobs 2.4 but it's worst, i have the yellow lightning on boot of Noobs.
      Any helps will appreciated.
      • Quemandoacromo
        Quemandoacromo last edited by
        @Sh_K If a yellow ray appears is because your power supply does not have enough power
          OyyoDams Staff @Quemandoacromo last edited by
          @quemandoacromo 3A power supply is required 🙂
          • Sh_K
            Sh_K last edited by
            Hi, after reading your answers, i noticed that i make an error, my power supply is 3000mA, is it possible the PS doesn't work properly ?
            I'm not encounter problem with Kodi, only with Recalbox.
            Thank you again.
            • Sh_K
              Sh_K last edited by
              @OyyoDams
              Hi, i try with another power supply 3000mA, but same problem...
              tested with PS Aukru and BERL5, any idea ? Maybe with another version of Recalbox ?
              Thank you.
                OyyoDams Staff @Sh_K last edited by
                @sh_k some RPI won't work with latest Noobs versions. Please refer to Noobs support, or try direct install of Recalbox from out website (without Noobs).
                • Sh_K
                  Sh_K last edited by
                  @sh_k said in Noobs / recalbox yellow lightning:
                  @OyyoDams
                  Ok, i understand my problem after reading several posts on the forum, i have a Pi3b+, and it seems not compatible with Recalbox at this time.
                  My bad... I must wait until a version of recalbox besome compatible with my Pi.
                  Thank you.
                  101.4k
