    Dosbox doesn't start
    Emulator Arcade/PC/Console
    dosbox
    4418
    • erbertmag
      erbertmag last edited by
      Software: Recalbox version 18.07.13
      Hardware: Raspberry PI 1 Model B
      I'm having some trouble in getting Dosbox to work (I followed the instructions from https://github.com/recalbox/recalbox-os/wiki/How-to-use-DOSBox-to-emulate-DOS-games).
      I've put the files for the "Duke nukem 3D" game in /recalbox/share/roms/dos/duke.pc, and inside that folder I've created a file dosbox.bat, that contains just two lines:
      c:
      duke3d.exe
      When I try to open that Game in the emulationstation GUI, the DOSBOX logo appears for about 1 second (see below) and come back to the emulation station... Something is preventing DOSBOX from starting.
      I've collected some logs just after I've tried to run the "Duke Nukem":
      ~/logs/es_launch_stderr.log:
      ALSA lib seq_hw.c:466:(snd_seq_hw_open) open /dev/snd/seq failed: No such file or directory
      ~/logs/es_launch_stdout.log:
      SDL_VIDEO_GL_DRIVER=/usr/lib/libGLESv2.so /usr/bin/dosbox -userconf -exit /recalbox/share/roms/dos/duke.pc/dosbox.bat -c set ROOT=/recalbox/share/roms/dos/duke.pc -vkeybd /usr/share/dosbox -conf /recalbox/share/system/configs/dosbox/dosbox.conf
      When I try to run the above command (exactly the contents of ~/logs/es_launch_stdout.log) from SSH, I got the following output:
      DOSBox version SVN
      Copyright 2002-2017 DOSBox Team, published under GNU GPL.
      CONFIG:Loading primary settings from config file /recalbox/share/system/.dosbox/dosbox-SVN.conf
      CONFIG:Loading additional settings from config file /recalbox/share/system/configs/dosbox/dosbox.conf
      Exit to error: Could not initialize video: Invalid window
      Besides Duke Nukem, I've tried to run another DOS program: an ancient DOS program called "visual player". Both works in my linux PC' dosbox but unfotunately dont work in recalbox.
      Questions:
      1. What I'm doing wrong?
      2. Is there something that I can do, some other log to collect?
      3. What "SDL_VIDEODRIVER" (https://wiki.libsdl.org/FAQUsingSDL) Recalbox's dosbox should use for RPi ? May be an issue related to this?
      Thanks in advance.
        Your only hope would be @lmerckx if he's not in holidays
        erbertmag 1 Reply Last reply Reply Quote 0
          voljega Banned @erbertmag last edited by
          @erbertmag change your dosbox.bat to
          c:
          dir
          pause
          duke3d.exe
          and do a screen capture to show us what appears on the screen
          • Dragu
            @erbertmag
            I posted once my dosbox.cfg concerning DN3, you need a local dosbox.cfg, it will not run with the standard dosbox.conf.
            https://forum.recalbox.com/topic/9240/duke-nukem-3d
            • erbertmag
              erbertmag @voljega last edited by
              @voljega I changed my dosbox.bat, and nothing changed (the dosbox splashscreen appears for about 1 second and then it returns to emulation station).
              • erbertmag
                erbertmag @Dragu last edited by
                @dragu I've tested with your dosbox.cfg, and nothing changed.
                I think that the problem may be related with the dosbox video driver not working ("Exit to error: Could not initialize video: Invalid window").
                • Dragu
                  Yes, but this error message
                  shows that you are not working with a local (inside duke.pc) dosbox.cfg but with the original dosbox.conf that will not work here.
                  • erbertmag
                    @dragu That message was before your advice. I confirm here that the ~/logs/es_launch_stdout.log contains the part of command line -conf /recalbox/share/roms/dos/duke.pc/dosbox.cfg.
                    • Quemandoacromo
                      Quemandoacromo last edited by Quemandoacromo
                      @erbertmag Which version are you using? I have 1.3D and it works without problems on Recalbox (18.07.13)
                      alt text
                      Loading - Duke Nukem 3D DOS VERSION (v1.3D)
                      alt text
                      Menu - Duke Nukem 3D DOS VERSION (v1.3D)
                      My dosbox.bat:
                      • duke3d.exe
                      PS: Confirmed that the latest version of GoG also works without problems if you remove all "the additions"
                        voljega Banned @erbertmag last edited by voljega
                        @erbertmag seems impossible so I suggest double checking everything, because your screen should be on pause.
                        Pay attention to upper case in file and dir names, they shouldn't appear at all
                        • Dragu
                          @ebertmag
                          I just downloaded the dosbox version from 180713, easy with 7-Zip that also uncompress .img files, without necessary to install the OS.
                          And I can also confirm, DN3D is working with this 180713 version. But, my jackrabbit I not. 🙂
                          What shows that dosbox is not really a strait development over time. And the jackrabbit dosbox version is not usable for DN3D, 0 -1 framerates.
                          • erbertmag
                            erbertmag @Substring last edited by
                            @substring said in Dosbox doesn't start:
                            @lmerckx
                            @lmerckx can you help me?
                            • Dragu
                              @erbertmag
                              Tu as bien défini une keymapper file xxxx.map au niveau de dosbox.cfg et qui existe dans ton répertoire ?
                              101.4k
