    controller not working in Kodi
    kodi
    2009
    • WacKEDmaN
      WacKEDmaN last edited by
      hi, im relatively new to recalbox ive managed to get it all setup and working fine on a raspberry pi 2 with roms from external HDD, now i want to setup kodi..
      but my controller isnt working (a/b/x/y buttons work, d-pad doesnt). ive setup the control multiple times in recalbox (as per instructions in both this forum and the wiki) but no matter what i do the d-pad..keyboard works..but i dont always have it plugged in..
      the controller is a gamerpi snes wannabe..
      i thought maybe kodi isnt reading the config from the HDD, so i set recalbox back to internal, redefined the controls, and started kodi, but i still have the exact same results...
      does any one have any ideas how to fix it? (it worked fine on the older version of recalbox!)
      • WacKEDmaN
        https://file.ac/nY8O6--rWgg/ heres my system info.. am i right in thinking the controllers dont match in recalbox and kodi?
          Substring @WacKEDmaN last edited by
          @wackedman i don't know much about the kodi pads setup. I just know it's very hacky, and i don't want to spend time on this knowing we should start the public beta for the next recalbox major upgrade in less than a month, and it will feature a much improved joystick manager
          Quemandoacromo 1 Reply Last reply Reply Quote 0
          • Quemandoacromo
            Quemandoacromo @Substring last edited by
            @substring @WacKEDmaN
            KODI v16 gives problems with controllers if you do not use any keymap but KODI v17 works without problems with any controller
              Substring @Quemandoacromo last edited by
              @quemandoacromo recalbox will try to autoconfigure pads in kodi 17 😉 may need a patch here and there though
              • Quemandoacromo
                @substring I think it is not necessary, KODI 17 automatically detects all controllers... Dualboot of Recalbox with OpenELEC works without problems, the controllers are configured automatically
                • WacKEDmaN
                  thanks peepz..ill dual boot until and wait for updated recalbox with kodi 17
