    Turning RecalBox off Safely on my Raspberry Pi 3
    turning recalbox safely
    • Robert Thurman
      Robert Thurman last edited by
      Hi I just installed RecalBox on my Rasp Pi 3, but I have no idea how to safely turn the system off before unplugging the power supply, I have checked out cases like Rasptendo but these are hard to get in Australia where I am located,
      I was wondering if their was a software approach to exiting RecalBox safely before unplugging power supply?, or if you can recommend any alternative cases that use python scripts like Rasptendo allows that turns of Raspberry Pi and RecalBox safely using a connected switch.
      Thanks for any help
        hello
        you need to go emulatiin menu.
        with start or with select
